EJ25 = STI?
I have a 2005 forester 2.5l turbo EJ25 engine and just found out it has STI block. I have replaced crank with EJ25 crank. Will it be the same as STI crank ?
Probably not and your block probably isn't the same as an sti either , the ej257 or 255 in sti trim run a semi closed deck block but I don't think the foresters do . But I maybe wrong
It is semi open deck block. That makes it EJ257 sti  block right?
As far as I'm aware the 2.5 ltr crank is the same across the range . As I think there's only 1 type of nitraded crank listed when you use them in a 2ltr block (to make a 2.1 stroker).
You could give the part numbers a cross check on import car parts website to be certain .
in classic 2ltrs it's not the block type that distinguishes it's a sti (they change over the years /versions).
It's the cams ,forged pistons /rods and headgaskets that are uprated but this could be different for the 2.5 as I'm not up to spec on newage
