Greg722 Posted March 26, 2016 Share Posted March 26, 2016 Hi, I am with family for Easter. The alarm on my Subaru is going off. I can unlock the car with the key, but the button does not work. So my alarm goes off and the immobilser wont let the engine start. When I turn the key ignition lights do turn on. I have recently changed the Battery, but changed it again this morning to be safe. As I am away I am desperate to get the car working again. Please help Greg Quote Link to comment Share on other sites More sharing options...
Greenmamba Posted March 26, 2016 Share Posted March 26, 2016 When you say you recently changed the Battery, you mean the key Battery or the car Battery? If the key Battery, is the battery sitting right and secondly, why was it changed recently? Last question - assume you don't have the keypad code number with you? Quote Link to comment Share on other sites More sharing options...
Greg722 Posted March 26, 2016 Author Share Posted March 26, 2016 Car Battery was changed last summer as was the key Battery (I changed it because the range was poor and hoped this would improve the range, unfortunatly it just seems that Subaru have a woeful range). When it stopped working today my first option was to re-change the Battery in the key just in case, but no change. I have since discovered a key pad in the fuse box area, but don't have the code. Quote Link to comment Share on other sites More sharing options...
Greg722 Posted March 26, 2016 Author Share Posted March 26, 2016 Im considering driving home (6 hour round trip) in a friends car to see if the code is in the service book. I have called subaru who say they dont hold the codes on Subaru UK do who wont be able to get back to me until Tuesday after the Easter weekend :( Quote Link to comment Share on other sites More sharing options...
Greenmamba Posted March 26, 2016 Share Posted March 26, 2016 Without the code, not sure what advice I can give. The immobiliser is waiting for a signal from the alarm module and somehow/why it's not getting one. Have you only the one key? As far as Subaru is concerned - when I bought mine, no code came with it. I went to the agent, proved the car was mine (V5, etc) and 10 mins later, got the 4 digit code. Good luck, sorry can't be more help. Quote Link to comment Share on other sites More sharing options...
Greg722 Posted March 26, 2016 Author Share Posted March 26, 2016 No problem, when I saw the keypad I thought this would be the case. Usefully my V5 is at home. Do you think this problem will be solved with the correct code? Any idea why for no apparent reason the car will suddenly drop its code? Quote Link to comment Share on other sites More sharing options...
Greenmamba Posted March 26, 2016 Share Posted March 26, 2016 No idea, sorry. Last thought - have you tried disconnecting the car Battery (with car key out of ignition), press the brake pedal (clears residual current) and re-connecting car Battery, then try remote/start? It's a long shot, I know but something I'd try last resort Quote Link to comment Share on other sites More sharing options...
Greg722 Posted March 26, 2016 Author Share Posted March 26, 2016 Tried to disconnect the Battery, and left it for 30 min before retrying this didnt help. But thanks very much for your responses. Quote Link to comment Share on other sites More sharing options...
Greg722 Posted March 26, 2016 Author Share Posted March 26, 2016 Oh yes have a spare key at home not here. Quote Link to comment Share on other sites More sharing options...
Greenmamba Posted March 26, 2016 Share Posted March 26, 2016 I'm out of ideas. Good luck. Quote Link to comment Share on other sites More sharing options...
david1972 Posted March 26, 2016 Share Posted March 26, 2016 Subaru should have the code - were able to give me mine when I got it serviced (by me) for the first time. I just asked; they just gave me it - simples. All they should need is your VIN number Quote Link to comment Share on other sites More sharing options...
Mr B Posted March 26, 2016 Share Posted March 26, 2016 Subaru may have a code but if it been changed by owners/dealers/garage then it won't be any good. Hopefully your remote at issue, go home get other key which assume is remote key same as one shown above & use that to disarm the car then use it to code a new 4 digit pin number > If it not the remote then google M30 alarm bypassing as they very easy disconnect & straight wire the immobiliser circuits, you can even buy a connector to plug in the alarm ecu harness to do it ... Quote Link to comment Share on other sites More sharing options...
Greg722 Posted March 27, 2016 Author Share Posted March 27, 2016 Update, I drove from Bournemouth to Nottingham and back last night to collect my spare key (yes as pictured above) and my code. Luckily the spare key worked so I am now back on the road. The first key still doesn't work, does it now need replacing? I will get home before I try anything with the code, but is there any guides on how to use the code and the key? Mr B you mentioned that it is possible to re-program the code, although I'm sure it is simple I would like to read a guide first as the consequences of !Removed! it up I assume will be very steep financially. Many thanks for all your help yesterday. Although there was little I could do, at least I knew that and thanks to you guys I was able to do something about it. Quote Link to comment Share on other sites More sharing options...
Greenmamba Posted March 27, 2016 Share Posted March 27, 2016 Good to hear, must be a problem with the one key. I'll attach a copy of my Sigma manual, if it's any good? Gives some pointers on key pad (pdf) Subaru sigma_m30_manual.pdf Quote Link to comment Share on other sites More sharing options...
Greg722 Posted March 27, 2016 Author Share Posted March 27, 2016 I had a quick flick through that is perfect thanks. Quote Link to comment Share on other sites More sharing options...
Mr B Posted March 27, 2016 Share Posted March 27, 2016 Pointers on adding new code are in my link in message above. also all procedures on reprogramming remotes etc are in this advanced manual > https://drive.google.com/open?id=0B7Ub2apq5-pfcjJhSm5XUHNyUzQ If your key needs repair look at this service > http://www.ebay.co.uk/itm/Subaru-1-Button-Remote-Key-REPAIR-SERVICE-Impreza-Legacy-Forester-/191793198064? Quote Link to comment Share on other sites More sharing options...
RommelPL Posted June 6, 2017 Share Posted June 6, 2017 If I will quickly replace batery in my key, do I need to re-program it? Because Battery in my key is going low... Thanks Quote Link to comment Share on other sites More sharing options...
Greenmamba Posted June 6, 2017 Share Posted June 6, 2017 It should not need reprogramming. Quote Link to comment Share on other sites More sharing options...
