Check engine light
Did you replace it exactly the way it came out ?
It was replaced by the garage I bought the car from. Proper technicians...allegedly.
I'd shine a torch down between the manifold and see what it looks like, if it doesn't go back exactly in at 45° it will flash up a cel, it's easy to install but a pita to install the right way, as the wire makes it want to rotate, the opposite direction
