Wrx waytey
Hi to all just got my first Subaru 2005 wrx type uk going to start upgrading soon it std at the mo all ideas welcome
Hello& welcome It's a slippery slope, you need to ask yourself what kind of power your looking for and what kind of budget you want to set
Would like about 350 - 400 bhp budget ok
I expect to change turbo injectors exhausts inter cooler fuel pumps remap big brakes etc just not sure what's the best and most suitable thanks Dave
Gearbox and internals will need changing at that sort of figure too. Wrx 5 speed box are prone to going pop over 350ftlb. Internals 350hp. Not that it's a straight line rule but the higher you push it the less reliability you have.
You probably won't get past 350 without spending a fair wacky, the internals on the engine wont take it, the 5speed box tends to protest at more than that too,
Exhaust fuel pump & a map will see you come to or over 300 depending on what turbo you have on it.
Welcome, as most above have said the standard box can't take those figures mine is roughly 340bhp and has about 370ft lb of torque and just blew it's box so be careful 😂
If that's the limit that's fine it's not about the money I want to make it the best I can its a project I've been looking forward to and with all your help and advise got to start some where exhaust induction best makes any suggestions please
