Replacement of drive belt on 2011 diesel outback
Does anyone know how hard it would be to replace the drive belts. Was thinking of doing it myself if not to hard. Is there anything that should be replaced at the same time, like water pump or tension pully etc. Either that of fire it into local mechanic and let him do it for me. 71K on the clock at the moment.
Sorry Tom, I'm not the diy mechanic type....less so for diesels too.
Hopefully some more mechanically minded members may be able to help you
That no problems. I may just ask the local person I use to do any major works to see his thoughts on it. It seems easy if you look at it but if something else needs to be replace I would not tackle it. Not something I want to mess up :blink:
