Uncle Tashie Posted June 1, 2016 Posted June 1, 2016 Evening peeps!!!! so today started ****, woke up late, rushed around like a bull in a china shop getting ready for work, grabbed my keys and jumped in the car. switched her on, waited for the pump to finish priming, and started her up. noticed the oil light was flickering away so instantly turned her off, waited for a couple of minutes then tried her again, same way i did the first time, ingnition on, let the pump prime, engage started. she sprung into life just as before came up on the cold start, oil light still glowing dimly, opened the door to see if i could hear any knocking but nothing, decided i'd leave her where she was and take the van to work instead as i didnt want to risk damaging her internals anymore than possibly whats happened already. tried to search for a wiring diagram for the oil pressure wiring but all i can find on wiring seems to be audio wiring, seems alot of people want to change the speakers........... could anyone help me either by putting up a link or picture of a pin out diagram that shows the loaction of connects and the like. she is a 2003 wrx blob wagon/hatch cheers for any help uncle tashie
Piggysniffer Posted June 17, 2016 Posted June 17, 2016 Sorry I can't help with this, how has it panned out ?
MJP02 Posted June 17, 2016 Posted June 17, 2016 very fast way to see if its the wiring, pull the plug off the sensor this should remove the earth signal the sensor gives when pressure is low. make sure the plug (single wire) is safe and not touching, start the car up as usual and if the light still flickers then u have a wiring issue if not either the sensor is faulty or you have low oil pressure
JamesJDMwagon Posted June 17, 2016 Posted June 17, 2016 Oil preasure switches are only £10 chuck one in. My friends civic type r did the same thing just flickers. So I put a new one in and a new pcv (coming Honda problem) and all was sorted 😊 Hope it's the switch
