Imprezza advice
Hi everyone only had my imprezza wrx for about a month , just started to experience vibration from gear stick it starts to shake a lot ,during gear change from 2nd to 3rd and so on ... Iv been reading that it could be the gear linkage anyone have any related problems , have no idea where I could get this done as to be honest as I'm not sure if there is anywhere in Gloucester that specialises in Subaru
I agree with what you have read would go with gear linkage. You could check the gear lever is all tight by lifting the gear gaiter surround from inside the car if you know how, not a big job but just limits a possible problem anything other then that is all done under the car :( But if it is it's not doing any damage, and if you go to MD Performance meet up I'm sure they could give it a look at while you are there ;) (Hint-Hint) ;)
Hi Becky yes we specialise in subaru and you are more than welcome to come down and we can take a look at your car for you
Problem half solved :)
Thanks will bring it in this week as I'm getting worried about it , it's defiantly getting worse , dreading the out come :(
Well hopefully i wont be as bad as you think will keep my fingers crossed for ya :)
i bought a gear linkage kit for mine,consists of 2 uprated rubbers,one on linkage itself,(you get full linkage mind)
and other on stabaliser bar,now as tight as ermmmm... no comment ,is about correct about now,if you not got sorted ,ile look for link,cost me  85 surcharge was 25 ,but u get back when u send yours
