Need help once again
I'm having another problem lol I bought some lowered springs but I went to undo the main bolts and they are not budging and I soaked them with gas plus (I think) so is there anyone that could change them at all or even help me do them coz it's doing my head in
Bolts on the lower part of the strut leg or the bolts that hold the top mount to the strut ?
If it's the lower ones mark the position with a dab of tip ex on the bolt and on the hub mounting point, spray some more plus gas on go for a brew, then get a half inch socket set on it with a suitable breaker bar and stand on it, should do the job.
If it's the top of suspension. You'll need spring compressors otherwise it will never budge,
Obviously that's all the advice I can give you as I'm 200+ miles away, sorry
