RobJE
Hi all.
I suspect that this may be a faulty sensor. I have had the old foz for just over a month and on about 6 occasions I've fired her up and the ABS and Brake warning lights have stayed on for the duration of the drive. the next time I've started her up the lights have not stayed on. This has been the same each time; I have not had the warning lights come on consecutive times.
If the sensor needs replacing how big a deal is this. I have replaced the rear pads and discs and the brakes work great.
Cheers
Probably one of the front sensors, cables tend fail due to movement/steering over time .
Worth visually check all the sensor wires & cleaning connector plugs with elec contact cleaner spray, also check the toothed ring on hub as if heavily corroded & full of crud it can effect sensor reading.
Sensors easy fit, nothing complicated, they not cheap though, around £100 region for new pattern part .
Cheers mate. I will give that try.  It makes sense; no pun intended
