engine check light
hi all,
need help asap1994 wrx just had new coolants and boost gauge fitted engine check light came on after now car wont go over 5000 rpm why is this is it in default mode
Adrian
help
Might have a vac leak from the boost gauge pipework.
Search for the classic self ecu code check on here . It will enable you to read the codes and reset the ecu [emoji6]
