Up grades
Okay couple of things, we have fitted a Ninja 2 back box and want to do next section of exhaust, which is the best one to go for and where from
Dump valve is there an advantage performance wise, if so which is a good one and again where from
Are there any shows on anywhere coming up
cheers
Hello,
Go for the mid section next, just a straight bolt up part and saves the hassle of mapping any cel lights that may arise (assuming yours is new age ) ?
As for the dv not really much advantage, most fit purely for noise, again be careful what you buy, some make the car run a bit lumpy and if your looking at hks or similar there are a lot of fakes around,
As for shows the last big one of the year is at santa pod on the 3rd of Oct,
If you want to join the club stand you'll need to book your ticket today before 10,
Depending on how much noise you want you have two options for the centre pipe:
Non-resonated - Louder, has the potential to drone
Resonated (albeit smaller than standard one) - a bit louder than standard but more civilised
Dump valve - Only really if you want the noise!
Dump valves make your mpg worse as with a dump valve fitted you tend to drive untill boost kicks in to get the dump on every change..
Well i do anyway lol
Cheers for info guys, now where best place for the exhaust, we are in West Midlands but don't mind a drive, been to scoobyworld a few weeks ago but open to suggestions,
