Clutch judder
David Wilkinson
Generally it's only really noticeable on pull away if it's to do with flywheel surface flatness .
As sandy said it can dissappear after a while once it beds in to the flywheel surface (if the ridges weren't exessive)
I've only ever fitted 4 clutches , 1 with a new lightweight exedy flywheel and the other 3 with old oe flywheels.
I never had any judder but I had the old ones I fitted skimmed ,cos they had visual "ridges" in them .
