Reputable garage for clutch - Midlands
Hi all,
After my remap it has become apparent that my clutch doesn't appreciate 360+ ft/lb torque!
It's for a 2008 Impreza STI Hatch
Starting to get a bit of slip now and want to catch it sooner rather than later.
Can anyone recommend a clutch & flywheel uprade and where is repuatubale for fitting in the Midlands area??
Thanks!
Subaru 4 u is down brimingham way I think, depends where in the mids you are, Roger Clark and tdr racing are also in the mids
Cheers, I'll give them a call tomorrow.
Any ideas roughly how much I could be looking at?
kamikaze racing know there stuff and i've had my blob serviced from them a couple of times, good hoenst people and you can stand around the car watch them do their thing :)
Around 350-400 depending on the clutch used, flywheel skim & spigot bearing, may even need a rear main oil seal, if it's looking tired best off changing it as for the sake of an extra 20 quid to do it while out, saves having to drop the box again
Good idea!
I'll most likely get a lightweight flywheel as the opportunity has arisen!
wish my clutch was that cheap hahahaha
