Cams
Would anyone know wot cams iv got in my ej20g on my 1993 classic trying to work out if I can put some sti cams in
I'd imagine they'd be standard wrx / uk turbo cams ,which are lowest lift /duration cams they put in turbo imprezas.
Afaik the v1sti cams are better and a straight swap.
I'm unsure if all the v2 sti cams are the same as the v1sti ,as some of the v2sti ra's have been known to have the under bucket shims (which might use a different profile on the cam journal).
Think piper ,Kent or Brian crower do uprated cams for most ej heads . Maybe you can cross check the part numbers to see if v2,v3/v4 cams fit ? .
As the v3/v4 sti cams are the most agressive cams subaru fitted to the pre phase 2 heads [emoji6]
