New age coil
Just a quick one guys I'm going to be doing new age coil convention on my classic soon just wanted to know will it need to be tweaked straight away or will it run fine I'm planning on getting it tweaked in couple months once I've got a few more bits together to make it worth while thanks
No bud, it won't need tweeking in.
As a newage coilpack conversion just increases spark strength to lessen the chance of a misfire and doesn't alter anything else .
It's definitely a worth while mod on a early classic. If your going to get the boost upped get a later my 97 (v3 ) classic map sensor and get the mapper to fit and scale it in . As the v1/v2 map sensor maxes out at 1.2 bar whereas the v3 onwards map sensor maxes at 1.7 [emoji6]
When I got my ecu I got a 3 bar map sensor with it think it was from a v3 :) last map he said there was no need for it as it developed a misfire around 4000rpm so had the turn boost down but he will fit it when I go back :)
