Hi all .has anyone got any ideas as to why I'm getting a stronger smell of full when I come to a stop.the car was ok yesterday but this morning I'm getting this smell is it due to the fact I was !Removed! freezing this morning lol or have I got a problem ?
Checked the fuel caps on tightly ?
Which end is the smell coming from ?
Fuel filler necks rust out eventually,
Filler neck ok,cap ok smells more like it's coming from the front too
Have a look around the fuel filter and injectors... injector leaking is probably more likely
Check all hose clamps on fuel lines in the engine bay are tight - cold tends to cause contraction and sometimes leakage.
As mamba said, fuel lines under inlet manifold leak a little when cold, it's a known thing, may even have been a recall 🤔
