DIY Debadging blobeye grill
Right ive just done mine and had the pics so il pop them on
I am in no way a mechanic im just sharing how i did it
Tools needed
Multi saw or hacksaw
Wet and dry paper
Matt black paint
Large citroen van to build custom paint booth
Right grill at the start
Turn the grill over and there are 6 - 8 clips that just pull off allowing the mesh to come off then with your prefered cutting method remove the badge section
If done close enough there will be some light sanding required to remove any excess one done it will look like this
Now the underside wont look as good as there will be a gap but you cant see it so who cares
Next you can use plastic filler if you want to remove the small lip at the back but i left it
Then you need a citroen relay van to build a custom spray booth. This could possible be a shed garage greenhouse what ever u like 😉 lol
Now one all the grill has been rubbed over with some 1500 wet and dry to give it a key you can prime and paint or as i did just paint strait away
One dry refit the grill mesh and put back on the car to get it looking like this20170306_141509.jpg
Easy job only takes a few hours
