Right, so my driver side rear tail light is out. Pulled the bulb which looked fine, but I replaced it anyways. Still not working? Any ideas? Checked the fuse as well and that looked ok.
Have you got a test light or multimeter to test if you have power to the bulb holder, could be a bad connection in the holder its self or a broken wire
I might have a voltmeter about somewhere. Will have to locate it. Think it could be a bad wire. Noticed some electrical tape around it. Probably has to do with when they connected the rear fog light in...wonder if it's messed with the wiring.
