Help Required - A/C Pump!!
Hi All,
Last week I saw a puff of 'smoke' or steam come through my vents with a clutchy smell accompanying it with the A/C on. This caused me to pull into the hard shoulder and turn the aircon off and wait a few minutes. All returned to normal and I haven't seen the problem again, however I was scared to turn the A/C on again incase it happened.
Anyway.. I finally felt brave enough to hit the A/C button and nothing happened, there was no 'click' of the relay, the engine revs didn't change slightly, absolutely nothing. More importantly the air temp did not change.
I checked the aircon pump and it is not engaging when the button is clicked.. it does not spin at all.
Any ideas? Could this be related (surely it must be!)? - would this be a relay going or the pump failing?
Thanks!
Matt
No sound like you have a leak if all the gas has leaked out the pump/compressor will not engage you need someone to find the leak someone that knows what thay are doing
Sent from my SM-G903F using Tapatalk
Thanks - I had it re-gassed at Kwik fit for £49 last week... think I can take it back and complain? Surely they have to pressure test the system before refilling?
Thay will do something call a leak test wich is done in a vacuum at -1bar wich is not good enough to find small laeks if you find a specialist thay should do a pressure test at 10bar with ofn if you go back to kwik fit dont let them put die in it as some dies will f**k the compressor
@Phillip1993 Great, thanks a lot mate appreciate the help, I'll take it to a local specialist and then go complain to Kwik Fit once I have some proof that it's leaked completely!
The argument with the tests the majority of the machines do, is it tests the seals the wrong way, like@Phillip1993 said, it's a vac test not pressure test
