Anyone fitted a Whiteline rear sway bar??
Just attempted to fit a whiteline adj rear sway bar and found tiebar reinforcement brackets do not align with existing droplink brackets - hole centres are about 2-3mm off. Has anyone else found this???
i dont really want to file and elongate hole in original mount to make fit if I can avoid. Brackets should fit...
Cheers
Can u post a picture of what you mean? Might make it easier to help you 😊
Here's a pic. Bracket is only resting there but you can see misalignment.. cheers
It's my understanding the bracket is there to strengthen the droplink,
What links have you got and do they fit with the rest of it ?
It might get a bit closer if you take some of that manky paint/corrosion type stuff out from underneath ? 🤔
Or else just bung a drill through it the size you want the bolt to be
I reckon if you slackened off the clamp put the droplink on and put the bolt through the bottom it would align enough then do the clamp up, before attaching the top of the link to the bar
Or this ... 😁
Cheers. It's not very photogenic eh?! I've not had a Japanese car over 10 years over that is mind! Turns out the bracket is part of a dodgy batch from the US. I'm blaming trump and waiting for the replacements to arrive,
