rattle top end drivers side
hi guys need bit of advice got my first wrx wagon 02 plate got a strange rattle coming from what i think is drivers side cylinder head area defo not bottom end drives spot on more noise when first started but quietens down but doesnt go away any advice whould be grate thanks in advance
Can you do a compression test on all the cylinders?
is there a loose heat shield on that model.
Sent from my SM-J320FN using Tapatalk
quick update turns out the noise was not cylinder head it was timing belt  tensioner all sorted now cheers guys
