Will saloon suspension fit my bugeye wagon are they the same
Hey guys well just to start this off my suspension took a !Removed! on me could be described as a mobile water bed / rideing a wave :blink: was jus wondering will suspension fit off a saloon model onto my wagon or are they different asking because ive been offered all four corners for a good deal thanks in advance :afro:
Not sure the rear top mounts may be different as they changed them at some point what year is the saloon that they are coming off ?
Another thing is the spring rate will be softer on the rear of the saloon than the wagon, you'll need a stiffer spring for it to sit correctly
Thanks for the reply its an 02 saloon mines an 01 wagon both bugeye
Sorry for late reply been mad at work so here's the link to the part No s for the wagon
http://opposedforces.com/parts/impreza/en_g11/type_63/suspension_and_axle/rear_shock_absorber/
And here for saloon
http://opposedforces.com/parts/impreza/en_g10/type_110/suspension_and_axle/rear_shock_absorber/
The saloon runs through to my02 but there's also an applied model code that runs from my00-my07
Which is this
http://opposedforces.com/parts/impreza/en_g11/type_13/suspension_and_axle/rear_shock_absorber/
Easiest thing to do is ask the seller to send you a pic of the top mounts, then check yours, subaru tended to mix and match, parts my97 forester used the same rear top mounts as a newage wagon, where you'd have assumed that it would have used classic wagon mounts
Your a star dude ill ask for some pics to compare to mine and ill have a look at the links you sent also thanks again:angel_not:
