96 impreza gc8 spedo !
Hey guys So I changed my gearbox and the spedo isn't working it was before but not now the new gearbox is in and the car is in limp mode I've tried cracking it up and it's tight in the box but still can't get anything the gearbox it the only thing I've touched so it shouldn't be behind the clocks is there anything else I can try ? I've ordered a new lower part of the cable but I'm a bit joubious because it was working , any help please guys [emoji106]
Have you done a ecu self code check ? If not have a squint in the tech section on here for the how 2 .
Its probably because the ecu needs a speed reading to help calculate load . Have you checked the upper and lower cable join and where the cable goes into the box ,are fitted correctly?
As they can be a pita to line up .
