Need advise on 64 wrx sti.
The head unit was already fitted when I bought her, but there's no sign that it wasn't factory fitted. I'll sort a pic when I get chance.
The spacers bring the wheels out just about perfect and there's no 'noticeable' difference in the drive or response.
As promised. 😊
And close ups of the wheels, I've had a slightly larger tire fitted (from 245/40 to 235/45) and it fills the arch nicely, but, I'm in the process of modifying my rear mud flaps as they rub slightly due to the stupid design of the bracket having protruding bolts instead of a recessed thread. 🤔
You got the tyre codes for what our have?
And also a link to tyre spacers?
5 hours ago, Pixyflash said:
As promised. 😊
Direnza hubcentric black series, 15mm.
Widely available, Google search for suppliers.
Michelin Crossclimate 235/45 r18.
Fitted locally via Blackcircles.
Please check that you're able to accommodate the spacers and tyres BEFORE buying. 🤔
Would be a proper mare to find out they don't fit after. 😲
BUMP !
Thanks for the info Pixy Flash. Just started a thread with regards to changing wheels and tyres and the TPMS system. Any words of wisdom ? I see you have Michelin cross climates fitted at present any feedback you could give ?
Thanks, going to order the spacers as you are right about the perfect offset to fill the arches.
