XV 2012 front wiper not working - help pls
Hi
got and XV 2012 with minor body damage, now fully repaired
only one issue left - front wiper motor not working
fuses ok
lever checked and 12v coming out follow the switch
wiper motor removed and works when 12v applied direct
any idea what I should do next
help appreciated
Silver500
Has by any chance the wiper arm been removed previously ?
20 minutes ago, silver500 said:
Hi
fuses ok
help appreciated
Silver500
had to removed the arms in order to check the motor
I mean before the problem arose
or the motors themselves need to be in a certain sequence for the movement to rotate correctly when fitted
as when they are loose it will just spin as it should
the motor not sipping at all
Would also check to see if the spline fitment on the arm itself is in good order. If worn motor will turn arms will stay still. Hope this helps.
the motor spins when 12v applied direct
was bodywork repair in area of wiper or its wiring ?
I would assume bad wiring or relay to start with, basic power and ground checks to start with at harness to motor and see where results lead you ...
where is the relay located ?
I have removed the glove box
still cant find it -
help appreciated
