Can a faulty stat cause water/coolant loss
It's a mate's car (98 Saab turbo)....I said no, but could blow the h/g if overheated (if not already gone, which I thinks what's wrong).....it's the coolant in the exp tank, keeps dropping
I would say the same as you. If there is no visible signs of a leak with fluid under the car after it's been parked up and left to cool down
ditto - ooooh Ive come over all Patrick Swayze :blink:
That couldn't have sound worse no matter how many time's I read it back to myself.... Maybe it's just me ;)
No, even if the stat is faulty, it doesn't produce a hole for the coolant to escape from.
HG is the suspect. Tell him to go and get the coolant 'sniff tested' at a garage.
He did and went from blue to green so h/g's buggered
