SUBARU Stage 3 cg clutch and flywheel question!
Hi I not long ago had a Subaru stage 3 clutch fitted and it seems to be one day launch off perfect other days it seems like it doesn’t fully release when foots fully off peddle am I doing something wrong here car is only running standard power at the moment so wouldn’t of imagined it been strained at all
cheers mark
What clutch is it ?
As the standard blue exedy clutch can handle about as much power as the 5 speed ty54 box can (just over 350hp with mechanical sympathy )
Could be something simple ie ...
Clutch still needs to " bedding in"
Fitter didn't refit the clutch return spring .
Clutch fluid needs refreshing.
Clutch slave needs bleeding .
12 hours ago, savage bulldogs said:
What clutch is it ?
It’s a CG paddle clutch bud stage 3 with lighted flywheel don’t about a 1000 mile on the clutch it just if you set off abit spritly some times it feels as it’s riding the clutch.
ill be on with the clutch fluid as I’ve not done this yet
