Da polishing advice
I have a black 2007 hawkeye Wrx and the paint is covered in swirls. The cars buffs up well but i know it could be better. Never used a DA polisher before.
I believe Scoobys have thin and soft paint which makes it harder to get the final finish compared to hard paint but easier to cut.
I don't  know if it has been cut down before and there is obviously a limit before you completely remove the clearcoat.
If I am going to invest £150 + for the gear but still have no idea, what advice could anyone bring to the table?
 I will try my mates old van for practice  (have not told him yet) but I still don't want to screw that up either. I know it is fairly safe to do unless your a bit stupid with a DA compared to a rotary. Do you guys measure the paint and if so how do you work put the clearcoat thickness?
Any advice on kit, pads, products technique please.
Thinking about the DA6 or pro version which comes with different throws 8 12 15 and 21 mm. What's best for a total noob?
Cheers
The guys at this place are brilliant at unbiased support and advice. Recently bought some DA kit from them to work on my new XV when I feel the paint has hardened up enough. They may be worth a visit if they are not too far from you. If you do visit be warned the car park is full of pot holes.
https://www.shopnshine.co.uk/
