Acceptable compression test results
Going to do a compression test on my 2001 wrx tomorrow while changing the plugs what numbers should i be looking for will be doing on a cold engine which I know isn't ideal but I'm suffering with a bad back (violins playing) so will take me over an hour to strip it (no exaggeration) any help will be appreciated thanks in advance.
Compression pressure should be between 142 and 171 and no more than 10 psi difference between all 4
126 across the board on cold engine how much trouble am I in
that way to low i get about 150 on cold
That's what I thought leak down test next to try and pinpoint the issue worst thing is engine has less than a 1000 miles on it
I know this is a long shot but could valve clearance cause low compression (i know I'm probably clutching at straws)
Thanks for the reply tidgy i 're tested them using a compression tester today with a cap of oil in each cylinder and no change (heard it was meant to increase pressure if it were rings but didn't change) the other concerning thing is it takes at atleas t 7 cranks to build 126psi
Thanks again for the reply gonna have a leak down test performed and will update when completed
