New to Subaru (and may not stay long!)
I'm more of a Toyota guy, but needed a cheap 4x4 in a hurry and couldn't find a decent RAV4, so bought a 2004 Outback 2.5. Initial impressions were very favourable, but on just its third outing it's started randomly sounding a very loud alarm inside the car. So, it's probably going back! But, I'll find an appropriate topic and post a query there - maybe it'll be something quick to fix.
did you put something on the passenger seat ??
it's pretty sensitive so might it be the belt alarm ?
or not .
Any warning lights on the dash lit when the alarm sounds?
other thing this can be with new owners who not read the manuals is the sat nav alarms .
Won't find much reason not to like a 2004 outback as they pretty damn solid especially the 6 cylinder model .
Wotcha and welcome - I occasionally get a very loud alarm inside the car - tends to be at 5K revs approaching a 'sporty' set of bends with the missus riding shotgun 😆
Apologies for the delay in replying everyone - I've been away. Thanks for the suggestions!
I found via google an article which mentioned a horn in a tray under the windscreen wipers, which gets full of water and debris and leads to damp getting into the horn. Sure enough, mine was covered in damp leaves. I was short of time so removed the debris and stuffed the horn full of blu tak to muffle it. Turns out this horn is for the security alarm and is not related to the problem (which still happens and is not muffled!).
I've read the manuals - no clues there, but I now think it's not related to the security alarm (and there's no sat nav).
There are no dashboard lights showing, but I will try opening a door while moving to see if it's the same horn.
The seatbelt suggestion is interesting and I'll look into that. And it does seem to kick off if I turn a corner quickly (which made me wonder if it was a dodgy door switch, but now I'm trying to recall if I had anything on the seat).
Bingo!
shms hit the nail on the head - I didn't know about the seatbelt alarm, and it turns out that my camera bag is just the right weight to set it off sometimes. Yes, there's a visual indicator, but it's not on the dashboard where I was looking - it's up by the sunroof controls, and not particularly visible in daylight.
Thanks for the suggestions everyone!
