Godders Posted October 29, 2018 Posted October 29, 2018 Apologies if this is Posted in the wrong place. 2 days into Impreza ownership the CEL comes on suggesting secondary air pump valve stuck open 馃槖 the 60amp slow blow fuse had blown and the closest Subaru main dealers only had a 50 which I replaced it with anyway, I鈥檓 expecting it to go again first thing in the morning now the outside temperature has dropped. So what鈥檚 the general consensus with these pumps? Subaru want an eye watering amount to replace the system but i鈥檓 aware they can be removed, blocked off and mapped out (I did this on the equivalent system on my old Yamaha R1 which was easy enough) but can these valves be cleaned manually and freed up at all or is it just not worth the hassle? Might be a good excuse to get hold of a prodrive back box and panel filter if it goes to a tuner 馃榿 Its a 2006 wrx completley standard with 56k on it. cheers guys 馃憤馃徎
Jay762 Posted October 29, 2018 Posted October 29, 2018 The problem with them being stuck open is it lets moisture back in which leads to corrosion - IMO I would remove and blank as you have suggested
