Should I have intercooler ducting, blobeye
I don't have any ducting on my scoop for the tmic, should I? It's a 2004 wrx. Is it okay without one?
Somebody must know ha. I just want to know if it actually does anything to help cooling of the tmic?
You're supposed to have a black rubber seal "scoop undertray" to make sure the airflow from the scoop is directed through the tmic adequately.
If the tmic isn't getting enough airflow it will suffer from heatsoak,  basically warming the intake air instead of cooling it .
You should be able to pick up a second hand under tray from a breakers "jdm solutions Suffolk" might have one in stock atm .
Just bear in mind if you have a wrx scoop and tmic you'll need a wrx undertray . If it's a sti scoop and tmic then you'll need a sti undertray 😉
Okay thanks its still got wrx scoop and tmic as far as I'm aware
Okay so iv found scoop tray local to me but it's of a hawkeye wrx will this fit my blobeye wrx?
