On at least up to bug eye , that pipe with the oil on is for coolant that passes through the cooler /modine.
So I'd say it's either from the filter seal , modine , the main bolt that connects through the modine or from above that . Like sump, cam cover or cam seal ect
Here's a pic of the early 92 to 96 oil cooler set up for a v1 /V2 from my service manual that might help .
Thanks man I have paperwork stating the cam seal was done in ‘17 it also says that a used sump was fitted however so that is possible. I’ll just need to systematically go through the lot cause I’ve tried taking it to mechanic and still have leakage 😔  thanks for the replies guys 👍
