what engine oil
i got a wrx 1994 engine and gearbox all seem fine i have only had it a couple of days and want to do an oil change but not sure on what oil to use i would like to no what you guys recommend
Myself I only use a named brand fully synthetic 10W50. I choose to use this. But since been told its the best one to have, by a guy who repair's and rebuilds Subaru engines. And another who works with Oil's.
Some other's might tell you what they use, or you can go to an Auto shop give them your reg they will be able to let you know what there computer tells them. But would always use a brand name and not Carlube like someone else I know, he's not had problems but would not trust it myself. I also use Blueprint filters :) but you can choose what you like I guess
ditto - fully synthetic 10W-50 - ensure it has a JASO or API standard conformance and you should be fine.
My Subaru manual gives quite a range of choice
1.5lt - 2.0lt
10W-30, 10W-40, 10W-50, 5W-30, 0W-20 - with a recommendation of the 0W-20 - however I was advised that would be too light as when the engine is stopped it all runs straight to the sump any residual cooling effect is lost and on start up there is little in the way of lubrication.
2.5lt turbo
10W-30, 10W-40, 10W-50, 5W-30 - with a recommendation for 5W-30
ok thanx for the advice  :)
