Twitchy steering
Hello all
I have a 2010 (60 plate) diesel
the steering feels a bit twitchy driving around town and on uneven surfaces (all tarmac)
Half the time the steering feels ‘normal’ the rest of the time it’s like I’ve gone over a patch of ice and the steering goes very light.
if I drive over a bump or pot hole the car wants to turn in that direction
one garage checked all the bushings etc and said it all looked good
another garage said it might be the diff winding up as there were different tyres being used (all the same size). As I was getting new tyres anyway I got 4 of the same put on but that has made very little difference
has anyone had a similar problem and found a solution?
thanks very much
Are you sure it's not tramlining?
Roads here are rubbish and I've had cars do this in the past.
I thought that but he has had new tyres which should have made a difference.
Just a quick update
just had the wheels tracked (all 4) and they were toeing in slightly
had them adjusted and.......
feels the same.  😞
If the wheels and tries are ok and what you describe is not normal then it must be the steering rack i guess. Are all the rubber gators intact on the rack.
Hello all
the car is booked into the local garage on the 3rd so I’ll let you know what they find
thanks for all or your help, have a good new year
Got the car back yesterday and the mechanic said.......
he he could find nothing wrong
he checked (and I stood next to him in the inspection pit) everything suggested on this forum (and the other 2 I posted on).
there might be a very small amount of play on the rear bushes (one of them) but I’m yet to find out how much this would cost to replace.
he said it didn’t feel too bad to him
either I’m too sensitive(which would be a first) or this is how these foresters drive. Either way I don’t think this is the right car for me.
anyone want a Forester?
thanks for all of your help
So the latest
a local garage could only find one fault
one of the bushes on the drivers side rear trailing arm had a small amount of play and he said that while it might not be the cause of the problem it would certainly not be helping. He said he would have to get the part from Subaru and would call with a price
after a couple of days and no word from the garage I called my local Subaru garage and inquired about the bushing. As he sounded like he knew what he was talking about I explained the situation so far. He offered to fit the bushes and then try to diagnose the fault.
i took the car over the next and had the work done while I waited. When he returned he told me that he had found the cause of my problem. It was...........
the steering rack
when they plugged the car into their SSM fault code reader is came back with
“found fault code 42 which is referring to can error. Most likely cause is the steering rack but possible for the controller to be faulty”
all in it it will cost £1278.75
now I have only owned the car for less than 2 months so I’m back to the car lot where it came from. They ‘should’ repair the car at their expense but they are already being awkward.
I'm taking it back on Monday 20th so fingers crossed
if anything else happens I’ll post it
thanks
Sorry to hear it is that amount. Glad you have a found the problem and posted it. How come this code was not found earlier? Good luck with the sellers.
Hi Siluro
the Subaru man told me that generic code readers can’t see this fault
im glad a fault has been found at least now I know that I’m not going mad
the ‘car lot’ are legally responsible to repair the car or refund the money
on a positive, the AA did a car inspection and the lot is affiliated with the AA. When I called them they said that the lot should fix the car and if there is a problem they would get involved and act as mediators.
So hopefully I’ve got some ‘back up’ when dealing with these shady guys
Ahh yes generic reader fair enough. At least you are not going mad as you say. Sounds like you will be ok and you can enjoy Subaru life (except the bad start).
Shady, do you think they knew, did you buy it like that then?
Siluro
when I test drove the car it would crunch when I put it into 3rd but not if I was shifting slowly and deliberately. The salesman said he had driven it and it was fine, so I thought it may just be my style of driving?
At the same time the front left wheel was out of balance (possibly due to a new tyre being fitted on that corner) and the steering felt ‘odd’. The salesman said the steering might feel different to normal because it was a 4x4!
As it came with a months warranty I thought I would take it home, pay for the wheels to be balanced and get on with life.
i didn’t mention the shifting issue to my wife. She took the car out and when she came back, said it was tricky to get into 3rd so I knew that had to be fixed.
long story short, the car lot either refurbished or replaced the gear box and it’s spot on
The rest of the saga is above
when I called them yesterday they were telling me that I should have taken out the extended warranty and that things wear out on old cars. They said I would need to take it back to them to take to one of their mechanics, it could be a couple of weeks and they don’t have a curtesy car available
They tried to put me off and made it awkward to get it looked at but I managed to work around them and got a date booked.
my concern is that they will claim there is no fault. With what has been diagnosed, there is no visible damage to the rack and a generic reader would not pick up on the fault code.
From my experience with the car lot so far, they keep their ‘eyes on the penny’s’ and will be in no rush to take it to Subaru for a diagnostic at £100 an hour never mind £1200 to fit a new rack.
‘Shady’ might not be a fair term to use but what ever the outcome I’ll not be buying a car from them again
so far it’s been hard work dealing with them
I hope it works out in your favour as it should. Good luck.
Latest so far
took the car back to the car lot on Monday and called this afternoon for an update
they told me the car was ready for collection
because they could not find a fault!
despite me taking in the diagnostic report from a Subaru dealership!
now the AA are involved and will hopefully get things done
lets see what’s next.........
Holly Molly. Nightmare. Good luck keep us updated. Interested if AA help you.
So after almost 3 weeks of mediation we can’t reach a resolution
They will refund the asking price, minus £400 for usage. Which I would deem fair if the car did not have an airbag fault resulting in a manufactures recall, rendering the passenger seat useless and dangerous.
Any legal professionals out there that can help would be appreciated
Thanks very much
