  1. Tap the 3-dot menu (⋼) in the top-right corner of the browser.
Why is this unplugged?
Good morning
Not a lot of time for the Subaru this last 18 month or sođŸ˜Ș, but was poking about the other day and found this and was wondering if anyone could shed light on why its disconnected.
Thanks Neil
Anyone?
I'm guessing it was done when new ECU was fitted
Sorry bud , didn't spot this post 1st time.
That's a barometric sensor , used to measure atmospheric air pressure,  so the ECU knows the density of the air coming into the engine to adjust fuelling.
What type is the "new ecu" ?
As most mappers tend to still leave that sensor connected to help with fuel trims
Thanks savage
I've got alkatec running mafless with added air temp sensor in the inlet
Having a aftermarket ait is probably why it's unplugged , as the ECU is able to read the air temperature . Not quite as good as having the atmospheric pressure as well but a ait does help with maf less fuel trims
Thanks I feel a bit better about it now
