Neil Posted February 15, 2020 Posted February 15, 2020 Good morning Not a lot of time for the Subaru this last 18 month or so馃槳, but was poking about the other day and found this and was wondering if anyone could shed light on why its disconnected. Thanks Neil
Neil Posted March 5, 2020 Author Posted March 5, 2020 Anyone? I'm guessing it was done when new ECU was fitted
savage bulldogs Posted March 6, 2020 Posted March 6, 2020 Sorry bud , didn't spot this post 1st time. That's a barometric sensor , used to measure atmospheric air pressure, so the ECU knows the density of the air coming into the engine to adjust fuelling. What type is the "new ecu" ? As most mappers tend to still leave that sensor connected to help with fuel trims
Neil Posted March 6, 2020 Author Posted March 6, 2020 Thanks savage I've got alkatec running mafless with added air temp sensor in the inlet
savage bulldogs Posted March 6, 2020 Posted March 6, 2020 Having a aftermarket ait is probably why it's unplugged , as the ECU is able to read the air temperature . Not quite as good as having the atmospheric pressure as well but a ait does help with maf less fuel trims
