Changing the diff oils??
 What’s the best oils for your diff? I’m servicing my car in the near future and thought I’d do the diff oils as well since I’ve never done it since I’ve had the car.
Tbh your better off contacting someone like opie oils or A.S performance to get the right grade and quality oil for your rear diff and usage .
I'd recommend to undo the filler bung at the top of the diff before undoing the drain plug at the bottom.  As they can sometimes corrode and seize,  so you want to make sure you can refill before emptying it 😉
