1998 import Subaru Impreza wrx restriction issue on revs
Advise what can it be
revs in every gear limited to 4000 revs
turbo spoiling all the time
Speedo doesn’t work
Could be boost control system fault , causing it to go into limp mode but have a search for classic self ecu code check in the tech section on here .
To see if you have any stored ecu codes , maybe check the vacuum lines in the engine bay ,especially to and from the boost solenoid/turbo .
