How to get correct part
Hi All,
My 2006 outback is now marking its territory with gear oil as the drivers side gearbox drive shaft seal is shot,
How can i be sure to get the correct seal as i don't want to be stranded with out a car as I need it for work?
The main stealer up here is "Too busy to deal with this at the moment" so any help appreciated [emoji106]
Sent from my SM-N976B using Tapatalk
Don't really know much about outback spec tbh but on impreza turbo manuals they're all the same from the 92 5 speed to the later (o2 onwards) sti 6 speed .
As I fitted the same seals in my 94 sti's 5 speed and then into the 6 speed I fitted a few years later .
You could try cross referencing part numbers for any outback drive shaft seals you can find online and if there's only one type /part number , you'd probably be ok to just order one .
Get a genuine subaru one though ,as most aftermarket seals and gaskets are sub standard and will probably leak again at some point
