Bumper removal
Hi, I need to remove the front bumper from my 2011 sti saloon and the first obstacles are the headlight pop up washer covers. Anyone know how to remove them without damaging anything? Thanx in advance.
The nozzle is held on by clips over a small tab each side, you can pull the washer unit out about 3 cm by hand then use a small watch makers type screwdriver to gently lever the clip over tab.
