cut out
Hi chaps, hows things?
i was just driving down the road at 60 and the old girl just cut out on me!!! i think it maybe the alarm/imobiliser so just wondering if any one knows where in the guildford area i can get it looked at that wont cost the earth?? also i have had the engine check light on since i,ve had her and think its time i had that sorted too so need to find somewhere to get her pluged into that also wont break the bank!!! any ideas????
cheers dan
Hi Dan sorry to hear the bad news I'm not from around there so not to sure on good places. Hopefully one of the other members will see the post and be able to help you out mate :)
on the earlier fre facelift classics theres a way to do a diagnostics check as well as wiping the error codes stored
heres how to check the faults click
and heres a list of what the codes are click
to reset the ecu the easiest was is to disconnect the battery for an hour, this will erase any old codes in there, best thing to do is wipe the codes first, after you have put battery back on drive round the block then check for fault codes, this way you know it's going to be fresh faults rather than an old one thats been fixed and not cleared, if you do get a fault and fix it make sure you clear the codes otherwise it may still show as an error despite being fixed
We have how to on both them think we need to find places they can be better found :D
There both pinned in this thread funny enough :D
i did look in certain parts but couldn't find them, maybe a dedicated technical info section with one for links and one for anybody that writes a big post on something
Think it needs addressing if people can't find them for sure
Even though it's the same thing just nice to have everything in one place for ease instead of linking off sites. how I see it anyway for this sort of information  :D
Cheers guys, I have found the fault code 35 and tried clearing it but it comes back straight away!! The trouble is I can't find the !Removed! purge valve!!!
firstly check the breather hoses they can get blocked somtimes with rust where they meet the metal pipes its really only for fuel vapour but check the lines to it one might be torn or ripped
secondly I'd check the wiring to the actual solenoid itself, they are prone to failing, some people disconnect them so just check it's all connected
Did you get this sorted?
You could always take your car to tfs racing in aldershot or Surrey Subaru specialist in camberley
