Waxoyl
Waxoyl rub in arches a yes or no just where u can get ur finger tip?
Plus it doesn’t seem to be drying will the moisture not cause rust I no it never fully drys but if it’s tacky.
I’m not quite sure what you mean by arch rub.
Ideally you need to degrease the area you are waxoyling, at least pressure wash away the grime.
allow it to dry and then apply the waxoyl. It does drive out moisture but the less added moisture it needs to drive out the better.
hope that helps
Do you mean the seam between the skins around the edge of the wheel arches?
Then it’s a yes for me clean and dry then pack it in where ever is possible.
it stays tacky for a little while but it does dry up
