2010 replacing struts end links lower control arm
So my girls 2010 Impreza needs struts sway bar end links & lower control arms. I don’t know much about adjustable struts except ride height. It is a daily but we have gone off-road with it. We do go camping & we’ve talked about raising it for more clearance. I guess we really don’t know what we should do. It is driven more on the street than off road. It needs struts swaybar end links lower control arms & swaybar bushings? This is a first for me as far as do it yourself. Is it worth getting performance parts if nothing is beeing done to the engine?
I would go with a mix of aftermarket and OEM - You can get beefier / adjustable drop links and replace the OEM rubber bushes with aftermarket poly items (No need to do the more solid option, some are stiffer than others) Replace your ball joint with a subaru item
