Mot emissions
Hi all
Would a jdm sti hawkeye 2005
still mapped for Japanese fuel
pass a uk emissions mot test
thankyou
the fuel octane mapping of factory tune make no real difference really to MOT emission test (it all mainly ignition timing tables at higher rpm/boost and wider throttle positions).. good order cat and oxygen sensors and the JDM grey imports passed Euro 3 emissions pretty easily when all components present and in good order .
One thing worth noting is MOT emission testing is harder for the tester to get a pass result as MOT body has very recently changed the setup so the emission result feeds directly to the system while your vehicle logged in for it's test and you only got a one chance run for the readings so ideally operator wants be sure vehicle nice & hot and no obvious likely issues prior to doing the test run as you can't do like before of nursing it through multi test runs until get a good enough reading manually input .
Thank you very much for taking the time to reply.
very helpful.
cheers.
Hi
just a follow up car sailed through emissions and mot.
cheers.
job jobbed, now have fun putting some miles on it ...
