Legacy 06 2.0 twinscroll (WHAT MODS TO GO FASTER?)
Hi guys I’ve got a 06 Spec B prefacelift Auto, I’m tracking the car next year and want to know what parts are a must have so the car don’t die on me 🤣 And also for styling make it look that lil meaner, here’s a list of what’s on the car
TEIN COILOVERS with adjustable damping controls
GFB blow of valve
HKS turbo timer
SYMS front strut brace
WEDSPORT ORIGINALS  NOT REPLICAS Lightweight alloy wheels.
Rear Diffuser
(IN THE POST)
EBC Red pads
EBC Front and rear discs grooved and drilled
Sparco mud flaps for the winter
FULL SERVICE DONE 30miles ago
ATF changed and filter
Engine oil changed and filter
K&N filter changed
Pollen filler hasn’t been changed yet but I have it ready to go in.
Timing belt and water pump will due end of next year.
As above for early warnings if pressure drops or it gets too hot .
The impreza classic, bug and blob all have fuel cut issues when low on fuel (1/4 tank and below ) whilst cornering hard right .
Due to the shape of the underside of the tank (hump to clear prop /diff) and the fuel pump pick up being on the right . Not sure if this applies to the legacy though ?
If so a spec c type fuel sock cage (in tank) or a external fuel swirl pot will help .
If you intend on really going for it on track, a baffled sump helps lessen the chance of the oil sloshing around in the sump and starving the oil pick up (losing oil pressure when cornering) .
As for faster , less weight , a decent geometry set up ,decent tyres and a remap .
