no radio reception
Right another question lads
Im not getting any radio reception at all. nothing. there is a blaupunkt unit instead of original and there is one thick black cable not connected anywhere. but its too short ( only a foot )  how does antenna works in these cars? do they have printed antenna?
I would try extend the black cable and test it I'me sure that will be the radio. I've not used or gone with a radio unit in my car and it's been awhile from the last time I was in that part of the dash. Only other way maybe is if you can get a dabs kit.
whats dabs kit mate ? :)
Its a digital signal kit for the radio.
the idea is you connect the kit to your existing aerial lead and you tune your radio to a particular frequency which is the signal coming from the digital kit, you then change stations using the digital tuner getting digital radio stations instead of your current head unit.
here is an example
http://www.ebay.co.uk/itm/Brand-New-Pure-Highway-DAB-Digital-Radio-In-Car-or-Portable-AUX-In-Out-ICT-/261111313161?pt=UK_In_Car_Technology&hash=item3ccb727309
Oh i see :)  i will need to have a better look when im off, cos the prewious owner left bunch of cables under passangers carpet and plugged to battery going to boot, none of them were connected to anything and none of them were aerial cable. I suspect it was some sort of homemade music install. i will take a pics when i get a chance ;)
As Jay said with the dabs kit :)
I would say he might have had a sub or an amp maybe both in the boot.
yeah thats what i think, there was also a big fuse which looked like oversized festoon bulb hooked to battery. i will investigate this further hopefuly thursday or friday
on the other hand - can i just get another aerial lead if original one is missing?
I would have thought so but doubt it would be easy to install. though thats why I said to look at the dabs stuff and you will get Digital Radio
right so now im getting reception but is sooo weak, if im on hill or open area then its ok, but driving through build up area or valley and nothing again :angry:
If I remember the blobeyes is in the rear window and it did suck for me too I ended up getting something like this but the unit in the car is one that gets freeview TV pop out dvd player thing.
http://www.ebay.co.uk/itm/AUTOLEADS-DAB-AA1-Glass-Mount-DAB-Digital-Car-Radio-Aerial-Antenna-SMB-Connector-/111195116986?pt=UK_Cars_Parts_Vehicles_Terminals_Cabling_ET&hash=item19e3bed5ba
But you might be able to get a booster
Like this
http://www.ebay.co.uk/itm/Car-radio-stereo-aerial-amplifier-booster-boosts-your-radio-reception-/151108528250?pt=UK_In_Car_Technology&hash=item232ec5287a
Great, saved in watch list, God, :unsure:  its growing for sure :D thank you for that mate
No problem I had the same problem I guess it's a blobeye thing :(
