Brake fluid question
Hi guys, Noticed today my brake fluid needs topped up, is it ok to mix brands as long as its all Dot 3 ?? I ask this as I dont know what kind is already in it.
yes that is fine - but as you have low fluid check your pad wear (I assume no leaks)
also if it hasnt been changed in a couple of years I would recommend a refresh with new fluid (I myself would go with Dot 5.1 as it has higher temp tolerance than 3)
Good point about the pads, I will check them first, is it ok to change to dot 5.1 with regards to the internals of the system??
Should be fine I have 5.1 in mine and never had a problem.
Don't even think you can get dot 3 anymore.
4 is a direct replacement, check with subaru if your unsure i think that 5 has a different chemical compsoition and could rot the lines and seals if not compatable.
5 is different that is silicone based which can affect the seals - 5.1 is different again but similar to 3 and 4 (just with higher temp tolerances) so shouldnt cause any damage to the rubber
Jay, thanks for that i assumed the two were the same as the mazda wouldn't accept either. I know what i'll be putting in mine at next change now :-)
