sigma problem
hi does anyone know how i can bypass my alarm key pad fob not working and i do not have pin code
I mate if I have uploaded it to my Google drive thing I will send you a link on a how too but not something I would post on the forum might need an email for the link to work not sure yet still working it all out ;)
Be interesting know this as I don't have a code for my alarm either
I can send you the Sigma30 guide too if you like matt I trust you have a Subaru in real life and not wanting to steal one Haha  :lol:
I try my best :D
I like to make people smile you never know it might be just what some people need in a day to change it for them :D
yes pal i got a bugeye not been able use it since sunday gutted lol
Hi there, what car you got?
bugeye wrx pal
Well just had a skim through the files I was given. Doesn't give an over ride code like I was told when I was sent them just shows you how to change them but I just quickly read one of the files so might be in the other one. But been called out so will check when I get back. :(
ok thank you mate its really doing my nut in now llol
Right I've just read through again :( only works with working keycode or a fob :(
Provided that you can disarm the system with a working Radio Key or the current PIN, then you can re-set the 4-digit PIN to one of your own choosing yourself, using the keypad, at any time.
If you do not have the current PIN, then option A is your best solution. However if you do not have a working Radio Key, then you will have to use option B and obtain the systems PIN code from Subaru (UK). Your dealer can obtain this for you if you can provide proof of ownership and the alarm systems 16-digit serial number.
A. Using a working Radio Key:
- Arm and then Disarm the system using a working Radio Key.
- Within 30 seconds of disarming, type into the keypad- *17856*92*wxyz*wxyz# (where wxyz is your new PIN code)
- Arm the system with the Radio Key
- You should now be able to disarm the system using the new PIN code
B. Using the current PIN Code (if a working Radio Key is not available):
- Arm and then Disarm the system using the current PIN
- Within 30 seconds of disarming, type into the keypad- **abcd*92*wxyz*wxyz# (where abcd is your current PIN code and wxyz your new PIN code)
- You should now be able to arm and disarm the system using the new PIN code
When using the keypad always observe the following points:
- The PIN number should not be entered too quickly or too slowly - when a digit has been pressed the small LED built into the keypad will illuminate briefly as confirmation and only then should the next digit be entered.
- If an incorrect digit is pressed or the delay between entering digits exceeds 10 seconds, then the LED above the keypad will flash rapidly and the PIN attempt should be aborted and started again after 30 seconds.
- Due to the small size of the keypad some users may find a rubber tipped pencil easier to use. DO NOT use the sharp tip of a ball point pen etc, or press excessively hard on the keypad as this will only damage the membrane and cause a digit to remain pressed, causing a continual incorrect PIN.
- The keypad allows only THREE PIN attempts and then will "Lock Up" if an incorrect number is entered a third time. This is a security feature to prevent random PIN attempts disarming the system.
The programming codes just go on and on, so not really suitable to post. What are you wanting to turn on or adjust?
So does this not affect me with having an aftermarket alarm? Will it have been disabled?
okat thanks anyway mate i been looking but not having any luck either  <_<
I have guides coming out my &#33;Removed&#33; all over the place for all sorts and get sent them too so don't get chance to look at them all in depth until someone asks :(
I will keep looking but without the fob or the keycode looks like Subaru so far are the only ones to reset it with bigish costs :(
And you will be fine BlackBosh I'm sure you could just use that Apache fly to Sigma and hold them up until they sort it with a threat of firing some Hellfire missiles at their HQ you will be fine ;)
Ha Im sure that would go down a treat with the MOD. Ive got the workshop technical guides in pdf format for all models up to 06 on disc if anyones interested in them i can put them on a file share
Just tell the MOD your mates with Harry. He's a legend 1st royal I like :D
I have 100's of guides mate more than I know what to do with but always interested to see if you have any I've not got :)
There up north so when im back ill post screen shots so you can have a look
No worries mate just when you can :)
I'm always loitering around here... I don't think the admin and the moderating staff has realized I'm here yet ;)
so it looks like im up **** street without a paddle lol if anyone as any luck and can help pls let me know  :(
It is looking that way mate :(
this is a company local to me but when i had a car with a sigma they were able to advise me on what to do with regards to the keypad as i didn't have any idea why it was there lol
http://www.basesystems.com/
