I went boost and oil pressure but wish I had a temp now too :(
But had the 2 for years now so won't worry about it for now :D
Pro Sport Evo's. I only got them just because I liked the startup sync they do :D and I was fed up of the boring looking analogue style ones too
Not the cheapest or wasn't when I got them not sure what they go for now. I still like them but I'm like a sexual driven fly with lights I'm attracted to them just like I am with a woman with brown hair :D
Gambit when you fitted your boost gauge did you T off from your dump valve? I had heard there ιs a spare albeit plugged outlet on the manifold!! But can I find ιt!!! Ggrr
I think this is a how too thread somewhere that Gambit has put some pics up... will have a dig
I found easiest place was on the intake side of manifold, look just below the bottom left coil/ignition lead and you'll see a newer peice of vac hose with the t peice a little further up.
Was told to get it as close to the maifold as possible for the best reading
I did look but wondered if ιt got lost on the downtime a while ago?
aaaah yes I had completely forgotten about that - that explains why I am searching for stuff I know has been there before but cannot find it :rolleyes:
No I didn't go from there I know there is about 3 points most people go from I will get a picture later for you if it helps mate from where I went from.
Cheers fella. I been cleaning again lol!! Fitted new pads on the front aswell. The scooby has to be the easiest car I have ever had to change pads on!! Love ιt
Not the best photo and I've not bothered given my engine bay a clean until the weather picks up :D
I've tried to mark it best I can to show where the T bit is
And I agree most things are so easy to work with. And other than a stuck piston it's the only thing that makes working with the brakes hard work
